Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 misfire/backfire
Old 11-09-2012, 12:11 PM
s-10again! s-10again! is offline
sounds like your distributor is a tooth off and you are compensating by turning the distributor untill it runs ok. sometimes you can get themn to run whene there a tooth off. ive been told its not possible to run a tooth off but by golly i made it work before lol...low power and unexplainable popping and rolling exhaust flameing while trying to use power. the idle sounded mean and the car would start right up and go.
