Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 misfire/backfire
Old 11-09-2012, 07:03 PM
hcompton hcompton is offline
Old & Furious
Move the wires to a different cylinder and make sure they are pushed down all the way. If the miss moves replace the wires. No effect replace the plugs and check the cap and rotor for wear. Rule out all the easy stuff first. You should be able to feel the push rod and tell if its the same clearence as all the others usally just by turning it and moving it up and down.
