350 modulator hookup - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2006, 08:43 PM
Could someone please tell me, does the vacuum line from the modulator go to carb port or intake manifold port?
Old 02-02-2006, 08:50 PM
joe350s10's Avatar
Bigger is better
i ran mine to the carb port (the lower port, not the upper ported vac port)
Seems to do just fine.
Old 02-02-2006, 09:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the modulator is designed to work with direct vacuum feed from the manifold
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
