350 Motor Carb/Motor trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2011, 01:25 PM
Hello,
My name is bobby and i own an 85 Trans Am. I got the car a little over a year ago and it's has been a project by all means of the word.
A few days ago the cars pick up coil went out and the distributor was pulled and we finally got it back in. During this whole process we replaced the ignition module and the spark plugs. We set the timing to 8 where we had it before and it cranked right up. When it's idling in park it runs fine and you can step on the gas and it revs nicely. But when you put the car in gear and barely get into the gas the car tries to die and the smell of gas is overwhelming. Before pulling the distributor the car wasn't running rich it was actually running very lean. When we were adjusting the timing the car backfired a couple of times but the carb is a holley 670 street avenger and it has the power valve blow out protection system or what not. When you get on the accelerator and let off about 1/3 let offs there is a small backfire some come through the carb others through the exhaust. Anyone have a clue as to what might stop the backfiring and lean the carb back up when it's in gear? I would much appreciate the advice.
Chevy 350 out of a 77 el camino
Vortec Heads
Medium Sized Lunati Cam
Holley 670 Street Avenger electric choke and vacuum secondaries
350 Turbo transmission although i have a 700r4 i plan to put in soon
Thanks guys
Bobby
Old 06-01-2011, 03:35 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by ClassicFirebird
Hello,
Vortec Heads
Thanks guys
Bobby
Sounds to me like you did blow out the power valve. And even though the carb has the blowout protection they will still blow out trust me and it also sounds like the timing may still be out too. JMO popping through the carb can also be the cam going flat or even a vacuum leak can cause it. But i would be checking into the power-valve and timing first IMHO and has anyone been trying to tune the carb?
Cole
carb help blower motor? nastysmallblock Engine 1 01-03-2011 08:55 PM
Starter motor giving me trouble hollywood2k Engine 3 11-19-2006 02:46 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 08:49 AM
Hotrodders Motor problem puzzler! Test your trouble-shooting skills! killerformula Engine 12 06-09-2004 09:43 AM
Carb or EFI, which one is better for my motor bigedd396 Engine 1 06-01-2004 03:41 PM
