350 Motor ping only when I accelerating - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2010, 06:25 AM
my 1974 Chevy 350 motor pinging only when I'm accelerating?
Old 09-29-2010, 06:36 AM
bubbahotep's Avatar
Timing too advanced, check your vac advance
or, low octane gas when you might need higher octane
tune up? Plugs could be cooked too
Old 09-29-2010, 06:47 AM
I will Try a Can of Higher Octane 104
The 350 Motor sit in a 1951 Chevy Truck with Auto Trans, 4bl it just started doing the ping when I accelerating, we take the truck to show and it sit in a warn gargae maybe week at a times
Old 09-29-2010, 07:13 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Definitately sounds like too much timing advance . There are several old posts on here about timing .
Old 09-29-2010, 09:08 AM
bubbahotep's Avatar
104 octane boost cans are fake, no increase in octane. Buy 92,93 octane gas and fill the tank to be sure. Sounds more timing related though
Old 09-29-2010, 12:04 PM
66SSImp454's Avatar
Justin
Too much advance.
Old 09-29-2010, 01:56 PM
Im having the same issue in my 50 Ford F1. I think mine is related to timing and Im going to recheck it tonight.
I replaced my valve springs and pushrods and now have this issue.
I also got it when I put bad 89 gas in it, before this valvespring replacement. I put the octane boost in and that did clear the issue too.
What about too much fuel pressure- Throwing too much gas into the intake?
just my two cents
Old 09-29-2010, 04:02 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
At any given time, how old would the gas in the tank be?
The motor may be detonating at all engine speeds, not just when accelerating, but may be less loud so that you cannot hear it over the operation of the engine and drivetrain.
The reason you hear it better under acceleration is that the system is coming up on its efficiency and packing the cylinders better than it can at lower rpm's and a light throttle.
Old 09-05-2012, 05:41 PM
sbc pinging
I have a pinging problem in my 350/400 hp sbc. I currently have a mallory unilite distributor . I tried setting my timing at 35,34,33 total timing at 3,000 rpm and still have the problem then i tried base timing at 8 and 10 btdc and lower, the engine ran bad. i started adjusting the allan key adjustment in the vacum advance canister counter clock wise to reduce the advance curve and want to know if anyone agrees i am on the right track or if anyone has any suggestions. thanks vinny
Old 09-06-2012, 04:23 AM
This post started and ended 2 years ago. I think you would get better advice if you starting a new post.
The Following User Says Thank You to 454C10 For This Useful Post:
sbnova (09-06-2012)
Old 09-06-2012, 12:35 PM
Depends under what conditions it pings. Pinging under acceleration has different causes than at cruise or at WOT. The big players are compression ratio, ignition advance, and mixture ratio. Other players are engine operating temperature, intake air temperature, and gearing which includes the effects of tire diameter.
So having an understanding of the engine's and vehicle's configuration, and under what circumstances it pings is necessary information to figure out the whys and remidies.
Bogie
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
