Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 needs more power
  #78 (permalink)
Old 09-08-2013, 08:55 PM
jokerZ71's Avatar
jokerZ71 jokerZ71 is offline
Wrench Turner
Either way you go,you will need gears & headers,so,I would start there.That will lay the groundwork for everything else.You can get an RPM intake,750 Q'jet,& a Lunati VooDoo cam kit for that $1000.Assuming your current motor is healthy,this combo would get that El Camino moving out pretty strong.Especially if your motor is the HO version w/ the flat tops & higher CR.
The Following User Says Thank You to jokerZ71 For This Useful Post:
eldudderino (09-09-2013)
