Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 needs more power
  #91 (permalink)
Old 09-11-2013, 04:30 PM
jokerZ71's Avatar
jokerZ71 jokerZ71 is offline
Wrench Turner
14010201 is the block casting #. It's an 82 to 85 2 bolt main 305.The 5.0 or 5.7 should be on top of the block,rite behind & below the drivers side head.The casting # & suffix code will also be on a pad just below the head on the passenger side if it hasn't been removed from decking.The suffix code will tell you what the engine originally came from.So,you have an 82 to 85 2 bolt 305 w/ 4 bbl heads.
