350 needs more power - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-02-2013, 10:01 PM
vinniekq2's Avatar
My Corvette(in picture) when I bought it,had the 160 HP 350.It ran well,it was rebuilt when I bought the car.It had stock heads,street dominator manifold,cheapo headers, 194 cam and a 650 holley double pumper.
I modified the carb with an 850 base plate and used a chasis dyno to tune the car.It have a measly 205 hp to the wheels and 279 pounds torque connected to 2.73 gears.
The car could barely get out of its own way.The cam was pathetic and it was low compression. I put a bigger,high compression engine in the car.It cost be 10k.
what do you want from your car?
  #17 (permalink)
Old 09-02-2013, 10:36 PM
vinniekq2's Avatar
if you want to go fast cheap,just buy a good ignition system(msd) good fuel pump and delivery system and a 150 HP nitrous system. total cost maybe a g note and you get 150 ish hp on demand.
It will boil the tires
  #18 (permalink)
Old 09-02-2013, 10:39 PM
Greg T's Avatar
www.krusinklassics.net
Get:
Aluminum heads with 58cc chambers, headers, 750 carb, Air Gap intake, cam in the area of 230* of duration @ .050", distributor recurve, 3:90/1 gears and a limited slip unit.
Have fun.
  #19 (permalink)
Old 09-03-2013, 04:59 AM
jokerZ71's Avatar
Wrench Turner
Gears will have the biggest bang for the buck.Then headers w/ good exhaust.Higher stall convertor.Transmission tuning.Then you will have laid the ground work for cam & other top end improvements.
  #20 (permalink)
Old 09-03-2013, 11:03 AM
vinniekq2's Avatar
gears/rear or transmission?
gears can be applied to the transmission as well as the differential.with out over drive,rear gears also adversley affect the fuel economy and comfort at highway speeds
  #21 (permalink)
Old 09-03-2013, 01:50 PM
techinspector1's Avatar
Wiki Edits: 326
First, find out what you have.
Warm the motor up thoroughly. Shut it off. Pull all the spark plugs to make the motor easier to turn over. Disable the coil. Remove the air filter assembly and wire the primary throttle blades wide open. Use a compression tester gauge to determine cylinder pressure and write it down for each cylinder. Doesn't matter if you use one that has a black rubber bullet that you push and hold into the spark plug hole or one that threads into the spark plug hole. Either one will work. Hold the bullet into the plug hole while your buddy grinds the starter motor. It will usually take 4 or 5 "chuffs" on the gauge (piston comes to top dead center on the compression stroke 4 or 5 times to load the gauge properly) to have a good reading, where the pressure stabilizes and will not go any higher.
If the motor isn't up to par on all cylinders, there will be no use to make any expensive changes in the first place. If all cylinders are equal and present a reasonable pressure, I agree with Vinnie about a 150 hp N2O shot. Cheapest and easiest way to gain 150 hp.
Spend $11 and get this used book by David Vizard delivered to your front door.....
Amazon.com: Buying Choices: Nitrous-Oxide Injection Amazon.com: Buying Choices: Nitrous-Oxide Injection
Nothing wrong with buying used books, I do it all the time to save some sheckels.
  #22 (permalink)
Old 09-03-2013, 06:09 PM
jokerZ71's Avatar
Wrench Turner
Rear gears within reason based on the type of driving.Milage will definitely suffer especially w/o OD.
  #23 (permalink)
Old 09-03-2013, 09:03 PM
what if i get a pair of 305 heads that would give me more compression right? and if i get headers put on and put some bigger gears do you think that will be enough what im trying to do with it basically is make it faster then all the mustangs running around in my town basically
  #24 (permalink)
Old 09-03-2013, 09:44 PM
jokerZ71's Avatar
Wrench Turner
If you do indeed have a 70's smog motor,you probably have 76 cc chambers & not so good flow.A 305 head would up your CR,but,you need a good flowing head as well.Not just any 305 head.A 305 head may raise your CR too much becuz of the much smaller chambers.A set of Vortec heads(64cc) would be a good upgrade.It would require a matching intake.There are also many aftermarket iron or aluminum heads available that would be even better depending on your budget.As has been stated,identify what you actually do have 1st.What do you really want the car to do?Beating all the Mustangs,is not the answer we're looking for.What kind of budget do you intend for it?How streetable do you want it to be?How many miles on the engine now?Remember,more power means more stress on an already tired engine is a sure way to finish it off.be realistic about what you have,what you want,& how much time,money,& work are you willing to put into it.It's gonna take more than a few bolt ons to beat ALL of the Mustangs!!! LOL.
The Following 2 Users Say Thank You to jokerZ71 For This Useful Post:
eldudderino (09-04-2013), techinspector1 (09-04-2013)
  #25 (permalink)
Old 09-03-2013, 09:58 PM
Proud LOSER
Its terrible that I'm afraid to answer this based on an ongoing thread elsewhere.
But hey, no guts no glory right?
A set of 416 casting heads can usually be found cheap or free. If your willing to put in the time, and I'm not talking a couple hours, I had 20+ hours in the last set I did, and a lot more in the first pair as they were a learning experience. That being said, with a generous home porting and attention to detail, this can be a fun path to some decent heads. But your going to need the right tools, a compressor, and as I said, time.
If this isn't what your looking to do, then there are other budget oriented choices that may be better suited.
What year mustangs are you attempting to play with.
What's your budget to put something together. And not just motor budget, rear end, trans, converter, and finally motor.....
Vinnie and tech may be on the right track for something simple for you.
Longtubes, a decent exhaust, a set of 373's, a performer RPM intake, a decent 4brl Carb, and a plate kit.
Drives normal 99% of the time, you find your mustang and spray yourself a win.
It doesn't get any more budget then that.
If you have a little more money, then there are much better choices then Nitrous.
You get out what you put in. I personally love the home ported 305 heads, a 268 cam, longtubes, performer rpm, Holley 750dp, 2800+ stall and 411's.....that's a fun, dirtball cheap street combo that should let you hang with a lightly modded fox body. It shoud put a beating on a lightly modded sn95 as well.
Most people will have other opinions, and they are right for them. If time, tools, or skill for head work isn't there, then look at some offshore casting alum heads, still much much better then what u have. If a little more money is available, look at better heads and more cam, brodix, pro-filer, summit or jegs house brands. All work well, all "inexpensive"
Just my humble opinion.
The Following 2 Users Say Thank You to bygddy For This Useful Post:
  #26 (permalink)
Old 09-04-2013, 01:35 PM
Wiki Edits: 326
STOP. Do the compression test that I outlined for you to determine if you have a platform to begin with.
  #27 (permalink)
Old 09-04-2013, 02:03 PM
jokerZ71's Avatar
Wrench Turner
You really need to know & be realistic about what your starting out with.Even tho you may not be using oil or smoking now,if you have a high milage engine & start throwing new parts on & tightening up the top end,the bottomend is gonna go KAPUT on ya really quik from the added stress & even wear patterns established in the current engine.Not to mention the fact that you will be frequently demonstrating your new found power.You may find that a new crate engine would be just as economical for the ground work for your "Mustang Eater".
The Following User Says Thank You to jokerZ71 For This Useful Post:
  #28 (permalink)
Old 09-04-2013, 02:21 PM
I would start off by getting some books, randomly throwing parts on a stock engine is NOT the way to go about it. How much money are you looking at spending?
Amazon Amazon
  #29 (permalink)
Old 09-04-2013, 02:29 PM
Amazon.com: small chevy: Books Amazon.com: small chevy: Books
  #30 (permalink)
Old 09-04-2013, 08:53 PM
im wanting to put like 1 grand in it as of now i dont have the money right now it will be bits and pieces this will be over like a year or 2 span of modding and stuff
el camino w/ 350
i have a 70's 350 dilema its a 350 out of old truck 2 barrel i need more power johnstubbs Hotrodding Basics 3 01-28-2012 05:05 PM
350 needs more power! Bauer1287 Engine 4 08-08-2011 11:24 AM
350 no power 350firebird Engine 13 07-07-2009 05:44 PM
How much power does my 350 have? chevymastermind Engine 5 09-27-2006 03:38 PM
350 power 83longchevy Engine 10 10-19-2005 11:39 PM
