350 needs more power - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-07-2013, 03:28 PM
well guys we have a problem......i looked up the casting number and it is a 305 the stock 305
The Following User Says Thank You to eldudderino For This Useful Post:
BigEd36 (09-21-2013)
  #32 (permalink)
Old 09-07-2013, 04:20 PM
vinniekq2's Avatar
when you decide what works best for you,ask how to get there. 350s are cheap
  #33 (permalink)
Old 09-07-2013, 04:37 PM
well i think the best rout is to find a 350 right now
  #34 (permalink)
Old 09-07-2013, 04:45 PM
techinspector1's Avatar
Wiki Edits: 326
Or a stock bore 400.
  #35 (permalink)
Old 09-07-2013, 04:47 PM
now thats a good idea or sell the car hahaha get something older
  #36 (permalink)
Old 09-07-2013, 05:02 PM
jokerZ71's Avatar
Wrench Turner
Take that $1000 you were gonna use on this motor,put it in a sock& then save up another $1000 & buy you a new L31 w/ a 5 yr/100,000 mile warranty. Problem solved !!!
  #37 (permalink)
Old 09-07-2013, 05:12 PM
jokerZ71's Avatar
Wrench Turner
You will have a brand new 1 piece rear seal,roller block for a solid fondation to build anything your heart desires.
  #38 (permalink)
Old 09-07-2013, 05:16 PM
that is a good point because i plan on having this car for a long time so why not do it right
  #39 (permalink)
Old 09-07-2013, 05:24 PM
jokerZ71's Avatar
Wrench Turner
You can get a new 2 bolt main L31 for $1875 or a 4 bolt for $50 more & free shipping.You can't build a decent engine for much less than that.
  #40 (permalink)
Old 09-07-2013, 07:34 PM
Originally Posted by F-BIRD'88 View Post
What is the casting number of the cylinder heads? (under the valve cover)
i dont know under the valve covers i looked on the back of the block and it was 14010201
  #41 (permalink)
Old 09-07-2013, 08:01 PM
jokerZ71's Avatar
Wrench Turner
The casting # of the heads will tell you if you have the HO version 305 or not.If it's the HO version,you may have somethin to work with.
  #42 (permalink)
Old 09-07-2013, 08:25 PM
well is the none HO version the one that was for California or something? from the VIN number it was made in Texas and Im from Illinois but i also looked up the intake number and it is an aluminum intake that they put on a caprice or something
  #43 (permalink)
Old 09-08-2013, 07:44 AM
pulled the valve covers this mourning and they are 416 heads
  #44 (permalink)
Old 09-08-2013, 08:18 AM
jokerZ71's Avatar
Wrench Turner
Most likely then you have the 305 HO. Unless someone replaced the heads.You should also have flat top pistons as well.With the rite parts & details,you can build a decent performer out of it.Best option would be,IMO,build a bulletproof bottomend,then blow it,or,add the bottle & go bust a few Mustangs in the ***** !!!
  #45 (permalink)
Old 09-08-2013, 08:22 AM
hahaha well im not sure man do you think porting them would do anything? im probably going to have this engine for a couple years maybe
el camino w/ 350
i have a 70's 350 dilema its a 350 out of old truck 2 barrel i need more power johnstubbs Hotrodding Basics 3 01-28-2012 04:05 PM
350 needs more power! Bauer1287 Engine 4 08-08-2011 10:24 AM
350 no power 350firebird Engine 13 07-07-2009 04:44 PM
How much power does my 350 have? chevymastermind Engine 5 09-27-2006 02:38 PM
350 power 83longchevy Engine 10 10-19-2005 10:39 PM
