350 needs more power - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 09-08-2013, 09:38 AM
or if i can find a 350 at a junkyard that would be another option maybe a 400 sbc maybe
  #47 (permalink)
Old 09-08-2013, 09:50 AM
vinniekq2's Avatar
Determine the power you need/want,then decide how to get there.Include budget in design.
  #48 (permalink)
Old 09-08-2013, 10:09 AM
if i can find a 96 or so vortec motor i can put a RPM intake on it right? and that should be good then headers and rear end gearing
  #49 (permalink)
Old 09-08-2013, 10:21 AM
vinniekq2's Avatar
intakes/headers and gears are available for most cars on the planet
  #50 (permalink)
Old 09-08-2013, 10:29 AM
jokerZ71's Avatar
Wrench Turner
I would definitley start w/ a later model roller block.The Vortec 350 is a good platform to start with.1 piece RMS,roller cam & lifters,heads that can support 400 HP.9.4:1 CR.Stock pistons are kinda crappy from a performance standpoint,but.overall,a good foundation to build on.
  #51 (permalink)
Old 09-08-2013, 11:54 AM
yeah man i think i can afford a supercharger on my budget
  #52 (permalink)
Old 09-08-2013, 12:11 PM
Proud LOSER
That sounded like sarcasm lol.....they re just trying to tell you all is not lost just because its a 305.
Being realistic, $1000 isn't a "budget" for performance anything. Its gas money for a couple months.
If its my El Camino, is not a daily driver, and its only purpose is to run a few mustangs down on a Fri night my $1000 goes like this
It likely has 342ish gears
$100 on a mini spool
$300 on long tubes, straight thru race bullets and turndowns
$100 on tune up parts
$250 on a used high rise intake and 650DP
$250 on a used plate kit and spray it with 150 shot.
If it breaks, who cares, its a 305 and the yard has plenty for sub $500 bucks.
  #53 (permalink)
Old 09-08-2013, 12:21 PM
Originally Posted by jokerZ71 View Post
Most likely then you have the 305 HO. Unless someone replaced the heads.You should also have flat top pistons as well.With the rite parts & details,you can build a decent performer out of it.Best option would be,IMO,build a bulletproof bottomend,then blow it,or,add the bottle & go bust a few Mustangs in the ***** !!!
Originally Posted by F-BIRD'88 View Post
Nice little street blower cam for your supercharged 305 with either ported 4416's or L31 vortec heads on it.
Bolt in with just a valve spring change.
Comp cams CS268AH-14 pn #12-404-4
Use a 750 or 800 or 850cfm carb.
Usually on these cars you use a Cowl induction hood (2.5" to 3") so the Edelbrock blower fits under El Camino hood. A small low profile hood scoop works too.
The Weiand 142cid blower is another very good way to supercharge this motor.
ya this thing is going to be my daily driver and i dont have the money yet to do anything but your answer is more realistic hahaha
  #54 (permalink)
Old 09-08-2013, 12:28 PM
well see the other thing is, is what if i blow up the engine now im SOL until i pull another one you know but nos maybe an option. if i port the heads and put another cam in it and a new intake will it perform ok?
  #55 (permalink)
Old 09-08-2013, 12:31 PM
i was also thinking today it would be fun having a strong 305 just saying to people that i have a 305 but it can actually do ok
  #56 (permalink)
Old 09-08-2013, 12:34 PM
ok if i port the heads and get a performer intake, headers, gears, cam would it do ok with those modifications or should i not waste my time and find a vortec 350 and put a RPM intake on it
  #57 (permalink)
Old 09-08-2013, 12:42 PM
what do i need if i get a new cam?
  #58 (permalink)
Old 09-08-2013, 12:47 PM
a 454 big block? it will fit? well damn hahaha but what would be the best rout a vortec motor or the one i got or trying to hunt down a BBC?
  #59 (permalink)
Old 09-08-2013, 07:06 PM
jokerZ71's Avatar
Wrench Turner
As of now,you really don't know what you have to work with.As fas i know,the 305 HO wasn't available in the El Camino,so somebody either switched heads.or,complete motors.If you have the 305 HO,it should have flat top pistons & 9.5:1 CR.If so.a healthier cam & matching valvetrain parts,a good intake,carb,& headers should get you a good runner w/ proper gearing.Just keep in mind tho,that it doesn't cost a penny more to do the same parts,same work,to a 350 w/ better results.As for wether you choose a Vortec,ir is already roller ready & the heads alone are already a 30 to 40 HP headstart.If considering a BBC,or,LS engine,it won't be plug n play.You will need everything especially with an LS swap.
  #60 (permalink)
Old 09-08-2013, 07:16 PM
jokerZ71's Avatar
Wrench Turner
If you decide to rod the 305,most of the parts you use will easily transfer to a 350 if you do swap later on for whatever reason.
el camino w/ 350
i have a 70's 350 dilema its a 350 out of old truck 2 barrel i need more power johnstubbs Hotrodding Basics 3 01-28-2012 05:05 PM
350 needs more power! Bauer1287 Engine 4 08-08-2011 11:24 AM
350 no power 350firebird Engine 13 07-07-2009 05:44 PM
How much power does my 350 have? chevymastermind Engine 5 09-27-2006 03:38 PM
350 power 83longchevy Engine 10 10-19-2005 11:39 PM
