350 needs more power - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 09-08-2013, 07:14 PM
well the guy i bought it from said there was a 350 in it and the block casting number says 305 (14010201) but he had to take the motor out because it isnt the stock intake and you can see where he painted the whole engine chevy orange because there are spots where the paint is flaking off and it is blue and the guy took out the A/C and the windshield washer fluid reservoir i dont know maybe that isnt the block number and is off the heads or something mayeb it is a 350 with 305 heads haha i dont know
  #62 (permalink)
Old 09-08-2013, 08:02 PM
jokerZ71's Avatar
Wrench Turner
Look @ the block just behind & below the drivers side head.You will see either a 5.7L or 5.0L along with some other #'s.You may need a mirror & some lite.
  #63 (permalink)
Old 09-08-2013, 08:31 PM
well thats where i looked was on the drivers side on the back of the engine and that is all i seen ill look agian if it should say 5.0l or 5.7l
  #64 (permalink)
Old 09-08-2013, 08:55 PM
jokerZ71's Avatar
Wrench Turner
Either way you go,you will need gears & headers,so,I would start there.That will lay the groundwork for everything else.You can get an RPM intake,750 Q'jet,& a Lunati VooDoo cam kit for that $1000.Assuming your current motor is healthy,this combo would get that El Camino moving out pretty strong.Especially if your motor is the HO version w/ the flat tops & higher CR.
The Following User Says Thank You to jokerZ71 For This Useful Post:
eldudderino (09-09-2013)
  #65 (permalink)
Old 09-09-2013, 02:14 AM
GMCTRUCKS's Avatar
F-bird would it be to much money for him to put in a 350 or 400 Poncho engine some older ones make some good power?
  #66 (permalink)
Old 09-09-2013, 04:42 PM
jokerZ71's Avatar
Wrench Turner
Without boost or nitrous,you can build the 305 to 275,maybe 300 HP & still have a dependable & fun daily street driver.After that,you are gonna start having drivability issues.That mite slay some of the average run of the mill 'stangs,but,not the 1's that have had any effort put into em,or.the later models w/ EFI,etc.You can take a new crate 350,or,a decently rebuilt 350,add headers w/ good exhaust,750 carb,or,EFI setup & have your 300 HP rite there.There are lots of options including the V6 F-bird mentioned.It just depends on what you want & how much time,effort,& $$$ you are willing to put out to have it.THE FASTER YOU WANNA GO,THE MORE IT COST !!! Lol.
  #67 (permalink)
Old 09-09-2013, 05:52 PM
yeah man i hear ya but i was thinking the first thing i could do is put new rear gears in it so that way i have more torque and then it will be matched greatly if i drop a new motor in it the mustangs around here are like 96 cobras and gt's and stuff and that blazer that beat me...hahaha and hondas ohh lord there are a lot of hondas
  #68 (permalink)
Old 09-09-2013, 06:00 PM
Proud LOSER
The earlier SN95 stangs were slow and heavy....they did get better in the later years, but your going to need a lot more then gears if its a 305 el Camino, the Honda's are an even bigger pain, its a complete crap shoot with them, could be a d15 with a fart can, or it could be a stripped hatch with a B18....one goes 17's, the other 13's....add boost and your screwed lol.
  #69 (permalink)
Old 09-09-2013, 06:13 PM
oh trust me they dont have anything besides fart cans man and the only mustang im worried about is a 96 cobra and he has exhaust work and a cold air intake but what ever i know not the mess with the muscle that is here hahaha
  #70 (permalink)
Old 09-09-2013, 06:30 PM
jokerZ71's Avatar
Wrench Turner
Gears would be a good start.You'll alwayz need em no matter which way you decide to go.
  #71 (permalink)
Old 09-09-2013, 07:42 PM
after the gears i might port the heads or something but i dont think i want to put alot of money into this motor by the sound of it, it seems to be cheaper to get good hp out of a 350 anyway and if i spend the money i would on the 305 to get the same out of a 350 then why not spend it on a 350 and make more power
  #72 (permalink)
Old 09-09-2013, 09:30 PM
jokerZ71's Avatar
Wrench Turner
Most parts you buy for the 305 will transfer over to the 350,except for maybe the intake if you end up goin to an L31,or even just Vortec heads.Think of your 305 as a "parts saving account" for the 350.LOL.IIRC,you already have a 4 bbl.The gears & a set of headers should make a pretty good increase.
eldudderino (09-10-2013)
  #73 (permalink)
Old 09-11-2013, 03:59 PM
ok so you said that there will be either 5.0l or 5.7l on the block well today i cleaned it good right by the casting number and it says 44 GM thats it so does that mean anything?
  #74 (permalink)
Old 09-11-2013, 04:03 PM
14010201 Details - CastingNumbers.info: Numbers for blocks, heads, and more ok i looked on this site and the number i have is heads so the block casting number where is it haha
  #75 (permalink)
Old 09-11-2013, 04:30 PM
jokerZ71's Avatar
Wrench Turner
14010201 is the block casting #. It's an 82 to 85 2 bolt main 305.The 5.0 or 5.7 should be on top of the block,rite behind & below the drivers side head.The casting # & suffix code will also be on a pad just below the head on the passenger side if it hasn't been removed from decking.The suffix code will tell you what the engine originally came from.So,you have an 82 to 85 2 bolt 305 w/ 4 bbl heads.
el camino w/ 350
i have a 70's 350 dilema its a 350 out of old truck 2 barrel i need more power johnstubbs Hotrodding Basics 3 01-28-2012 04:05 PM
350 needs more power! Bauer1287 Engine 4 08-08-2011 10:24 AM
350 no power 350firebird Engine 13 07-07-2009 04:44 PM
How much power does my 350 have? chevymastermind Engine 5 09-27-2006 02:38 PM
350 power 83longchevy Engine 10 10-19-2005 10:39 PM
