Thread Tools Search this Thread share on Facebook
  #1
Old 01-18-2012, 05:23 AM
cabrez99's Avatar
cabrez99 cabrez99 is offline
350 - No power, won't rev up
what's up hot rodders
my 350 chevy motor for some reason won't rev past 3500 rpm while on park, throttle response is not at its best. Does anyone know what could be the problem with it.
thanks
Register now (free) or login to remove ads
Old 01-18-2012, 07:47 AM
455olds 455olds is offline
Have you changed anything recently? What ignition and carb are you running? Points or HEI? Have you tried a tune up? What SBC, 350 or 305? Does it rev past 3,500 in gear?
Old 01-18-2012, 07:50 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is online now
Last journal entry: Fresh paint
Wiki Edits: 9
Welcome to the board
We need much more information, year, intake, ignition, vehicle, etc.
I've seen loss of power from collapsed mufflers and cats, but without more info hard to tell with yours. Is this after you added something, did work on it?
You also need to title your threads correctly, something like "need help" or "engine problem" doesn't work well, read the guidelines. I'll change it here.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 01-18-2012, 11:33 AM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
X3 more info please.
Cole
Old 01-19-2012, 12:24 AM
cabrez99's Avatar
I purchased the truck from a friend that purchased it from another friend. I don't know the history behind the engine and what was the issue, i just got basic information.
Motor is a 350 between 70-80, it has an MSD pro billet distributor, MSD blaster 2 coil, MSD 6AL box, Holley carb. I've recently did an oil change when i got the truck, i haven't yet did a tune-up on the engine.
I hope this is enough information to help find the issue.
Thanks
Old 01-19-2012, 06:21 AM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Check the MSD box to be sure there is not a rev limiter pellet in it to start with. After that I would look at the float levels.
Chet
Old 01-20-2012, 12:50 AM
cabrez99's Avatar
Ok, so I took a look at the ignition module it has an 8000 module. I've checked the carb it's a double pumper, but a performance carb, the vacuum seems fine and no leaks. Could it be a breathing problem coming from the top end or is it time for an engine rebuild.
Old 01-20-2012, 07:06 AM
cobalt327's Avatar
cobalt327 cobalt327 is online now
WFO
Wiki Edits: 1,616
Pull out the 8000 pill to see if it improves. You will now not have any rev limit- but w/an 8000 pill you really didn't, anyway.
Old 01-20-2012, 08:42 AM
AutoGear AutoGear is online now
to Cobalt: Valve float = rev limit?
What kind of exhaust system do you have? Id say disconnect everything from the mufflers back and see if that helps. Ive also seen some clunker MSD parts but they make zillions of em, there's bound to be a few clunkers.
What kind of oil pressure are you getting?
what kind of fuel system is on this?
Have you set the timing? Check the timing marks too, sometimes that ring can move and cause all kinds of hell although I doubt it
Does it sound good? no popping, pinging or back firing?
Old 01-20-2012, 11:36 PM
cabrez99's Avatar
Motor run and idles fine, I've also notice that while slowly revving up towards 4000 rpm I hear a slight knock. Oil pressure will be up at 40 psi and then drops down to 15-20 psi and remains there. I removed the pill and still same thing. It has hook headers with dual flow masters, it runs on 87 octane pump gas. I will detach the exhaust system over the weekend and see if there is a change.
Stand fast,
Old 01-20-2012, 11:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Stand fast,
Sounds to me like you're well on your way to spinning a bearing. This isn't going to be an easy fix, plan on pulling the engine and disassembling it to get to the root of the problems. I'd also avoid running it until you've at least pulled the pan and inspected the bearings and journals.
Old 01-21-2012, 01:51 AM
cabrez99's Avatar
Sounds like I'm going to have to pull the motor out and rebuild the whole motor.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 - No power, won't rev up"
ThreadThread StarterForumRepliesLast Post
power steering pump for sbc with MustangII power racTheCiscoKidSuspension - Brakes - Steering410-06-2011 12:59 PM
Power Disk and Power SteeringGreat '48Suspension - Brakes - Steering709-05-2005 08:35 PM
67 nova power sterring not power assist?turbonovaSuspension - Brakes - Steering612-20-2004 06:52 PM
power brakes and power steering on a '63 impala SSBenni520Hotrodders' Lounge210-14-2002 09:49 PM
anyone know anything about putting power brakes and power steering on a '63 impala SSBenni520Suspension - Brakes - Steering010-14-2002 01:22 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
