350 non lockup tranny (no shift) - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2006, 07:59 AM
James medley (jim dandy)
I have a good hotrod buddy (he does not have a computer).
He has a 39 chevy w/a 80 camero fuel enjected 350 sbc. Trans. will not shift out of 1st gear. (for @ rev) OK He ckecked for vacuum back to modulator, changed valve. Removed @ ckeck ed gov. gear. . any in put on what else would cause no up
shift, short of pulling trans.
Any advice will be apreaciated Hotrodders.
Old 12-16-2006, 09:09 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
lets see here:
What is the history on this trans? Mileage, recent repair or rebuild work?
He checked the plastic governor gear = good
He checked the vacuum at the modulator & has replaced the modulator. Vacuum feed is direct manifold vacuum?? 14 to 16 inches of vacuum at the modulator as the engine idles?
Has he checked the kick down cable from the trans for free movement? Does the trans have a cable? Does the cable easily pull and return?
700R4 Tranny Shift Problem riesman20 Transmission - Rearend 2 10-13-2006 11:21 PM
350 tranny question rwruther Transmission - Rearend 2 05-03-2005 10:07 AM
Tranny won't shift out of 1st if i floor it th350!!! 61ChevyTruck Transmission - Rearend 17 08-31-2004 02:23 PM
Trans Go JR. Shift Kit -Tranny Experts What does it do???. acr Transmission - Rearend 3 07-18-2004 06:09 PM
installing a 350 or 400 tranny zeeman19 Transmission - Rearend 4 07-02-2002 06:18 AM
