350 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2012, 06:02 PM
350 nova
Wireing harness 3 brown 1black left. have alt. temp sending unit. Brake hooked up. 1 wire to light on hood. Trying to which goes to coil. 1 brown would go to oil sending unit. But it has a oil gauge. Basket case car,almost togeather. Need to figure out wireing. Switched to hei insted of points distributor. Does any one have a 73 they could look at.
Old 02-13-2012, 06:46 PM
EOD Guy's Avatar
All I have is a dia for a 72 chevelle..... should be close.
HEI needs a switched 12v and one for the tach…..if you have a tach.
I'd remove the pur wire (in the 72 dia) from the coil and either tape it up or remove it completely. It is the resistance wire for the points/coil type system and will not work well with the HEI.
I’d also remove the Yel wire from the "I" terminal on the starter, it was used to provide a full 12volts while cranking, after it started the "I" terminal went dead and the coil got 9ish volts from the run position on the ing switch (the pur wire removed above).
Run a new wire from the 12v terminal on the HEI to a switched 12 volt (hot in run and start) at the ing switch…… that will give you 12 volts needed to pwr the HEI
Old 02-13-2012, 08:45 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Autozone offers wiring diagrams, testing and repair procedures for many production vehicles.
Go to www.autozone.com
You will need to register and create a password.
From the dropdown select the vehicle (new).
Select the category. Vehicle repair guides.
Next you will find listings of repair categories or chapters. Navigate to wiring diagrams, testing or repair procedures etc. Then select the desired item.
vicrod
help true 69 Nova SS? ansd a 66 nova FS MusclecarBob Hotrodders' Lounge 4 01-08-2009 08:54 PM
74 nova luger18 Introduce Yourself 5 03-25-2008 10:50 AM
Me and my nova Samantha Introduce Yourself 3 03-16-2006 11:43 AM
Nova vankissm Introduce Yourself 2 08-29-2005 11:21 AM
69 nova HotRod63 Suspension - Brakes - Steering 1 02-21-2003 06:15 PM
