350 with odd casting number... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2012, 01:53 AM
Chapter Founder
Hi all, my engine is confirmed 350. The back side casting code says it's a 350 but the front passenger side head casting number can't be seen. I'll I see is the number "22." I know that crate engines don't usually have the casting code so I'm thinking its a crate? I was told when I first bought it that it was either a 71 or 77 (can't remember the year he said) corvette engine. I think it's a 71 because he also had a 71 stingray at the time an I think he put that stock engine in the elky. Any ideas? If u need pics to maybe help just say so. Please and thanks guys.
Old 11-17-2012, 02:49 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Are you talking about a number cast into the head or the numbers stamped on the pad in front of the head, on the block?
Semper Fi
Old 11-17-2012, 05:01 AM
Chapter Founder
The number I'm referring to is the one stamped into the pad on the front of the block. The number that would indicate the factory, year, original vehicle and all that.
Old 11-17-2012, 06:01 AM
Maybe the block has been decked which is why you can't see the numbers. Is the motor out of the vehicle so you can get a good look? Crate motors have numbers stamped on the front of the block usually starting with the letters CE.
Old 11-17-2012, 07:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use the casting numbers and date code. If there is no suffix code, it was removed during block decking or was never there in the first place (OTC block or possibly a replacement engine).
Old 11-17-2012, 09:49 AM
Chapter Founder
Originally Posted by F-BIRD'88 View Post
remove a valve cover to read the head casting number.
If I did that would it give me the head numbers only or block too? I know the heads are double hump. The engine code is a faded 22 unless maybe there's some other place on the block that has the code?
Old 11-17-2012, 06:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Dude, follow the link in my last post above- everything you need to know is laid out for you. And no- the block casting number cannot be found on the cylinder head.
Old 11-17-2012, 09:08 PM
Chapter Founder
I know where to find the casting number but te block number is non existent. Atleast from what I can see (or can't lol) it's a pain because I don't have my garage renovations done yet so I can't pull the engine and just replace it with a 427 or 454 that I know everything about. If anyone has any suggestions for a 65 elky please let me know.
Old 11-17-2012, 11:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I fail to see what the suffix code will tell you that is of any real value. Things like what foundry cast it, and the assembly month and day, and what vehicle the engine was installed in originally means basically nothing in the greater scheme of things.
What you want to know AFA for buying parts, etc. is the displacement and when the block was cast- and even the date isn't important if you can tell if the crank is a large or small journal, if it has a 1 or 2 piece rear main seal, and whether it is equipped to use a factory hydraulic cam.
Old 11-18-2012, 12:07 AM
Chapter Founder
It's displacement is 358, a 4 bolt main with a .480 lift cam and the casting number is still visible so I'll post those numbers soon. I really appreciate everyone's help, almost nobody I know knows about cars so extra advice is appreciated. Here is a pic of the flyer from when I bought it and the guy had no idea what was going on because he bought it and never started working on it himself.
casting code, corvette, crate, engine, missing
casting number Jacomass Engine 0 01-04-2012 03:32 PM
Need help with 350 Chevy Casting number needlecreek Engine 4 03-02-2011 06:42 PM
Is My Chevy A 350 W/this Casting Number 3970010 CHEVY70 Hotrodding Basics 7 05-16-2010 09:06 AM
odd 327 casting camino_man Engine 4 04-15-2005 07:52 PM
350 casting number problem KentuckyCamaro Hotrodders' Lounge 8 11-01-2002 05:01 PM
