350 Oil Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2002, 07:08 PM
Dave E Shank's Avatar
Post 350 Oil Leak
My 350 Chebby engine is leaving its deposits on the floor at the rear of engine. I have been just changing the newspaper weekly but that does't cure problem. It isn't all that bad! Is there a simple cure without pulling pan ( exhaust in way ) and replacing rear seal?? I think that is where it is coming from. Any simple solutions??? THANKS Dave E Shank
Old 10-14-2002, 07:13 PM
Post
If the motor was getting worn anyway, Id be tempted to try some gunk in a can products, but if the motor runs decent otherwise, id drop the pan and replace the seal, i isnt that big a job, just alot of busted knuckles....
