350 oil ring depth - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 06:03 PM
350 oil ring depth
I am rebuilding a later model 350 chevy engine casting#14093638 87-94.
My question is, how can I tell if the pistons require the shallow or deep oil
rings? Is there a measurement I can use to determine this? I have read up and only find that VIN K uses shallow. I don't know original application ,but block pad is stamped V0705 UZH
Old 10-27-2010, 06:06 PM
bigdog7373's Avatar
Of course it's fast
Well you don't have a k block so you use normal rings.
Old 10-27-2010, 09:50 PM
SSedan64's Avatar
Code-- Year-- CID-- Vehicle-- HP-- RPO-- Trans-- Carb
UZH---- 91--- 350-- Truck--- 210- L-05--------- TBI
This a VIN K engine.
Old 10-28-2010, 05:14 PM
Thanks guys
Thank you for your info, I can now order rings and proceed with build.
Old 10-28-2010, 08:52 PM
SSedan64's Avatar
Welcome,
My Browser is screwed. Arrrrg!
Post above should have said " This is a VIN K Engine".
Todd
Old 10-29-2010, 01:35 PM
OK now I am confused, big dog says not a vin K engine SSedan says this is a vin K engine. Any way to verify which?
Old 10-29-2010, 05:38 PM
SSedan64's Avatar
I went here >> http://www.rockauto.com/catalog/raframecatalog.php and looked up a 91 chevy truck. You can look at other auto parts sites as well. Only 350 TBI engine available for that year is the VIN K, Truck, Blazer or Van.
Old 10-29-2010, 08:30 PM
Thank you once again for the help.JW
Chevy 350 oil leak Dan Denman Hotrodding Basics 2 11-07-2007 09:27 AM
Need help,Pontiac 400 BEN24 Engine 4 09-05-2007 01:26 PM
350 shooting oil MERCKX72 Engine 3 01-01-2005 03:30 PM
GMC 350 Top End Oil Problem bns2002 Engine 16 12-11-2003 03:29 PM
