350 Olds Engine on Any Olds - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2003, 10:56 PM
7skylark6's Avatar
Hi All! I have a 350 engine and trans. that came of a 1976 oldsmobile cutlass supreme, fixed up.
I have a 1982 Oldsmobile Cutlass Supreme 4 door, with no engine or trans. Anyone know if it will fit without a problem?
Help me out
Old 12-02-2003, 11:04 PM
billman's Avatar
Unless I'm mistaken the '76 Olds 350 was actually the Chevy 350. Provided the '82 was a V-8 it should work. If the '82 was a V-6 you will probably have to scrounge the V-8 frame side engine mounts from a junkyard. Should be no problem.
Old 12-03-2003, 03:15 AM
I believe the 307-330-350-403 up to 1986 were all Olds motors, and are interchangeable, so if the car came with one of those, you can drop a 350 right in.
Old 12-03-2003, 07:10 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Your car will support every GM engine from the little Chevy 200 v-6 to the Cadillac 500 and everything else that was available in GM's rear wheel drive vehicles lineup from the 60's to the mid 90's barring a few truck only applications.
Search for my previous posts and you will find some recent informative answers to this particular question.
Old 12-12-2003, 02:10 PM
New Member
You are correct, sir. The 76 motor is definitely an Olds motor. The 82 should be the same, other than what engine originally came in it.
Old 12-12-2003, 04:19 PM
Auto-Part's Avatar
It will fit like a glove. Go for it. How did you find such a jewel of a combo
Old 12-12-2003, 05:29 PM
badknuckles's Avatar
you talkin to me?
auto part i think i smell carcasm
Old 12-12-2003, 07:04 PM
bigblockbill's Avatar
i think bad knuckles is right
Old 12-12-2003, 07:17 PM
7skylark6's Avatar
Thanks guys i will go for it. See what happens
I will try to get all the pictures up of the project as soon as i start on it.
