350 olds head gasket help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2005, 02:35 PM
Ok, I noticed that some olds 350 head gaskets are from 68-80 and some are listed from 68-76. Whats up with that? I know the 77 and later olds use 1/2 inch head bolts instead of the older 7/16, but the 68-76 gaskets will fit the 1/2 inch headbolts of the later blocks.
Also, does anyone know the dish size of the cheap cast "rebuilder" pistons? I know they have a shorter compression height.
Thanks.
Old 05-04-2005, 09:46 PM
Anybody?
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head gasket ? bowtieorbust Engine 1 05-08-2004 02:13 AM
Best dressing for steel head gasket Steve B Engine 4 11-27-2003 02:18 AM
i'm assuming head gasket hlweyl Engine 4 11-26-2003 02:27 PM
intro and head gasket questions 4tinysquirrels Engine 4 09-14-2003 06:37 PM
