Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Pistons?
Thread: 350 Pistons?
Old 05-28-2006, 07:13 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Open up a Summit catalog, they have several listings for 327 pistons. Some are hypereutectic and others are forged. Listed compression ratios are from 7.65:1 to 11.86:1. Should you choose to order a set you'll want to calculate your compression with the actual parts you will be using. The listed ratios are merely guidelines.
