350 Pistons? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2006, 03:54 PM
AMERICAN MUSCLE!!!!!!!!!
350 Pistons?
Just alittle ? im not for sure about but in Jegs or any car magazine they have 350 pistons in there but do not have 327. im not for sure but are 350 pistons the same thing as 327 pistons. just diffrent rod length. thanks any help i would appreciate...thanks Allen
Old 05-28-2006, 04:03 PM
BOBCRMAN@aol.com's Avatar
MOST 350 pistons have a bit different skirt design than 327 but ALL 350 pistons have a different pin height than a 327. 350 pistons in your 327 will have the piston WELL below deck and about 5.4-1 compression ratio..
Any of the aftermkt dealers can get 327 pistons, just have to be ordered and cost much more than 350's. Low production/demand= higher cost.. A fact of life in the automotive world..
Old 05-28-2006, 07:13 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Open up a Summit catalog, they have several listings for 327 pistons. Some are hypereutectic and others are forged. Listed compression ratios are from 7.65:1 to 11.86:1. Should you choose to order a set you'll want to calculate your compression with the actual parts you will be using. The listed ratios are merely guidelines.
Old 05-28-2006, 07:23 PM
DoubleVision's Avatar
Speed Pro has a hyper piston with a flat top 2 valve relief, with teflon coated skirts all over Ebay for around $170, I think dirt track thunder carries them also. Thing is, be careful of what kind of pistons you get, if you buy the common cast "rebuilder" pistons, it`ll have .020 off the compression height, then when at top dead center, the piston will be .045 in the hole, this pistons kill compression, quench, and power.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
Cutting down Hyperuetectic pistons??? sizemoremk Engine 10 03-19-2005 08:22 PM
350 and 400 Speed Pro pistons Witlash Engine 1 02-16-2004 06:30 PM
350 crank in 327 1962MotorheadMike Engine 1 11-16-2002 06:17 PM
