350 in place of a 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2013, 11:08 PM
I have a '91 Sierra 1500 with a tired 305 and a 5-speed manual. I'd like to replace the 305 with a 350 for more power but need some guidance. It's a daily driver so mileage is also a bit of a consideration. First, which 350 should I order? Next, which EFI should I use? Thanks.
Old 03-13-2013, 04:58 AM
The GM Goodwrench or GM Performance Parts sites show which engine to use as a replacement for your vehicle. However, if you want to reuse the stock fuel injection you will need additional parts to adjust for the switch from a 305 to a 350. Which stock fuel injection do you have (I don't recall exactly when GM switched from TBI in the trucks), or do you plan to use an aftermarket setup? Many of the aftermarket EFI setups (Edelbrock, Holley, etc.) are more expensive than the replacement engine will be.
I checked Pace Performance and they had the direct replacement 305 for $1650 and the 350 for $1950. Local GM dealers sell the same engine, and they may meet the price. I got one from a Peterbilt dealer, since they were an authorized GM reseller. These are new engines and they come with a 3 yr/100k GM warranty. You could probably get a rebuilt engine locally for quite a bit less, but quality will depend on the rebuilder.
Bruce
Old 03-13-2013, 10:38 AM
You will need to change the chip in the computer for a 350 with manual gear box. The program in the 305 chip which controls the on-off time of the injectors (yes the 2 injectors of the TBI do sequence) this controls the amount of fuel delivered to the engine since pressure is maintained at a steady amount sequencing the injector time on against time off is the only way to meter fuel against the engine's immediate need. The 350 is 45 cubic inches or 15 percent larger in size so the injectors will need to be turned on 15 perccent longer to get the added fuel required by the larger displacement. This is an over-simplification of what's going on but it is basically correct.
The 350 will in fact start and run on the stock 305 computer farily well but it will have a lean mixture in most operating zones which will result in surging and bucking and expose the engine to the risk of detonation and excessive heating of the exhaust valves. Another way to get more fuel in is to replace the TBI's non-adjustable fuel pressure regulator with an adjustable replacement. This works pretty well in a somewhat sloppy way, if you have to pass emissions this would not do it for you.
An alternative is to have custom chip made which may be the easier solution with the 5 speed since most 350s sat in front of an automatic. See this guy for chip <<< TBI CHIPS >>>.
Bogie
swapping a T-400 in place of a T-350 what do i need? jims72 Transmission - Rearend 5 03-15-2010 12:43 PM
Best place to buy zz4 350 lt1tyrell Engine 2 08-06-2009 07:15 PM
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 02:51 AM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 05:28 PM
TH-350's Line presshure all over the place Old School Nut Transmission - Rearend 5 07-20-2004 11:27 PM
