350 power - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2005, 02:36 AM
350 power
Can ya'll let me know what i need to do to get more power out of my 1983 chevy 350. It would be very helpful.
Old 10-17-2005, 03:32 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Expound a little please.
What vehicle?
what do you want to do with it?
how much money?
Is mileage important?
Old 10-17-2005, 04:44 PM
AMERICAN MUSCLE!!!!!!!!!
Put some ported heads, 4 barrel intake, bored heads, good cam, good carb. that will add some major HP especially cam and carb.
Old 10-17-2005, 05:41 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
How much do you want to spend? $50? $500? or maybe even $5000? That is probably the #1 question right there.
Old 10-17-2005, 07:48 PM
jesse01's Avatar
mini me
you should give us a $$$$ estimate first
but you should stroke it thats a good start to some serious hp. than w/a matched set of AFR heads and cam you'd definetly do some damage then
J
Old 10-18-2005, 01:59 AM
xntrik's Avatar
There ya go....
3 out of 4 want to know how much do you want to spend.
Old 10-18-2005, 03:57 AM
docvette's Avatar
Wiki Edits: 12
Power
Doc here
As much as you can afford...
And also afford to feed..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-19-2005, 08:15 AM
answers
The motor is in a 1983 chevy long bed pickup. (sierra) The truck is just going to be used for street and strip. I am looking to spend i would say 2000-5000 on the motor. I just rebuilt the motor about 6 months ago. it probably has about 1000 miles on it since i done that. I put a comp cam (315 duration) 750cfm carb, intake, and gear drive timing, and headers. The motor is strong but not strong enough. It still has a stock 3-speed behind it and stock gears in the rearend. So that should give you and idea of what has been done to the motor.
Old 10-19-2005, 08:32 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Give us a full list of what's been done to eh engine. With a cam that long with stock gearing and a heavy truck, of course it'll feel slow, It is! What gear, trans type, and all the specs of the engine you can come up with please.
Old 10-19-2005, 07:45 PM
Blazin72's Avatar
Wiki Edits: 19
Yeah, the first thing you need to do is get rid of that monster cam. Which intake did you install? What heads are do you have on it now and how much compression does the engine have? Step that cam down to maybe a 225@.050 and shoot for 9.5-10:1 compression. Since look like you're willing to spend a decent amount of money invest in some good heads like some Iron Eagle 180s or something (if you havent done so already), maybe even 200s depending on how you go about (re)building the engine. Your engine might still feel sluggish until about 2000 rpm or so but it'll would have good mid range power.
I put a 236@.050 cam in my truck and it is a dog until about 2500 rpm but it really begins to take off after that. A good ignition is also a must and find a torque converter that matches as closely as possible to the combination you have.
Old 10-19-2005, 11:39 PM
xntrik's Avatar
"This seems like dejavu all over again."
(we just did a truck 2 weeks ago)
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 05:28 PM
How much power can a turbo 350 take ratfink14 Transmission - Rearend 4 07-22-2003 10:45 PM
79 Z28 350 / auto with no power brandma Engine 1 07-10-2003 03:28 PM
i need the most horse power for street performance out of a 350 rocket any ideas olds86rocket Hotrodders' Lounge 2 02-19-2003 09:07 PM
