350 powergilde acts like it is in drive, won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 07:23 PM
I have a 69 nova with a 350 powerglide that is acting like it is not in park when i try to start the car. I had put the car in neutral and rolled it out of my garage about 10 feet to clean then rolled it back in. The following week I attempted to take the car out for a spin and nothing happens. Doesn't attempt to crank as if the car was in gear but it is surely in park. I've checked all the usually suspects, battery, starter etc. Any one have suggestions on what my issue could be?
Old 03-03-2012, 09:54 PM
Wiki Edits: 85
First, do you have a 350 transmission or a Powerglide transmission?
Regardless of which it is, since you are getting no power to your starter, and you have checked some of the usual suspects, I think I would check to see if the Neutral Safety Switch is bad or is not working for some other reason. And, no, I have no clue where the NSS is located, other than it is not located on the transmission.
Old 03-03-2012, 10:05 PM
snydski's Avatar
snydski
Last journal entry: 72 ' 3970010
the neutral safety switch is on the column under the dash on old nova's . Does the car tug in park when started?
Old 03-04-2012, 03:27 PM
Thanks, I am going to look for that switch this weekend. When it did start I never noticed it tugging in park.
327 Acts like intake leak corvettepoor Engine 50 09-09-2005 09:41 PM
350 sb just rebuilt and it will not turn at all acts like its seized up Hpbbster72 Engine 9 09-16-2004 04:57 PM
Engine acts really weird grandprix601 Engine 7 09-04-2004 09:27 PM
My trac-loc acts like a spool shockers69 Transmission - Rearend 4 08-14-2004 07:06 AM
