-   -   350 problems Dead Cylinder! (http://www.hotrodders.com/forum/350-problems-dead-cylinder-60823.html)
wed68 04-03-2005 08:38 PM
Recently rebuilt 350, ran very well for 300 miles then started missing badly, checked compression #2 was dead no compression. I readjusted valves on #2 but had to back them off to the point that they make noise to get compression, now I have compression but the miss is still there! The ignition system is fine I have fire on all eight cylinders and the compression on all is 150#
What else do I look for?
Bill
lluciano77 04-03-2005 09:09 PM
Is the pushrod the right length? Maybe you wore out a cam lobe.
67 Deuce 4 Me 04-03-2005 09:33 PM
sounds like a valve or valve seat problem to me. Loosen the rockers so the valves wont open and do a leak down test. if you have a mechanical problem it will be obvious. Air will come out of the carb or exhaust or crankcase........Ed
tresi 04-03-2005 10:15 PM
My guess would be that you burned the valve /seat while running it woth the valves set too tight.
