350 problems Dead Cylinder! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 08:38 PM
New Member
Recently rebuilt 350, ran very well for 300 miles then started missing badly, checked compression #2 was dead no compression. I readjusted valves on #2 but had to back them off to the point that they make noise to get compression, now I have compression but the miss is still there! The ignition system is fine I have fire on all eight cylinders and the compression on all is 150#
What else do I look for?
Bill
Old 04-03-2005, 09:09 PM
lluciano77's Avatar
Is the pushrod the right length? Maybe you wore out a cam lobe.
Old 04-03-2005, 09:33 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
sounds like a valve or valve seat problem to me. Loosen the rockers so the valves wont open and do a leak down test. if you have a mechanical problem it will be obvious. Air will come out of the carb or exhaust or crankcase........Ed
Old 04-03-2005, 10:15 PM
My guess would be that you burned the valve /seat while running it woth the valves set too tight.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Theory: Intake volume vs cylinder volume / engine vacuum 59vette Engine 6 04-29-2004 01:03 PM
231 engine swap with buick 350 Hot_Rod_Faith Engine 1 12-20-2003 01:20 PM
Finding top dead center no. 1 cylinder Levi Engine 17 12-07-2002 12:34 AM
TH 350 shift problems Bigblazer Transmission - Rearend 5 12-06-2002 03:02 PM
