Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Pushrod length
Old 01-30-2013, 10:29 AM
shane.,herold shane.,herold is offline
longer studs?
cobalt, the hex head on the stud is where i am having interference problems with the base of the rockers.
I dont remember the spring specs its been awhile, the cam specs are
Intake Duration at 050 inch Lift: 250
Exhaust Duration at 050 inch Lift: 260
Duration at 050 inch Lift: 250 int./260 exh.
Advertised Intake Duration: 283
Advertised Exhaust Duration: 290
Advertised Duration: 283 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.533 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.553 in.
Valve Lift with Factory Rocker Arm Ratio: 0.533 int./0.553 exh.
Lobe Separation (degrees): 106
