Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Pushrod length
Old 01-31-2013, 11:14 AM
oldbogie oldbogie is offline
Originally Posted by shane.,herold View Post
I am going to take it to the machinist to look at. Im thinkin the head bosses need to be cut about .0350. And the rockers are Harland Sharp, a very high quality company, not summit. The cam is from summit, and since there are only a few places in the country that grind cams it really doesnt matter what brand they are, pick the one you want, and thats what i did. I have had excellent luck with all summit products because they are usually name brand stuff with a differnt label on them and a hell of a better price.
Were the rocker stud bosses originally machined for screw in studs?
The boss used for the press in stud has to be machined away, you can't just pull the press-in studs then tap the hole for a screw in stud. Additionally, when using guide plates under the stud the boss needs to be machined lower to also accomodate the thickness of the plate.
Bogie
