-   -   350 question (http://www.hotrodders.com/forum/350-question-109688.html)
350rebuilder 02-22-2007 05:22 PM
350 question
what size engine CID and liter would my 350 be with the 383 stroker kit and .030 overbore
poncho62 02-22-2007 05:25 PM
Doesn't a 383 kit require a .030 overbore?
If so....383/6.3 litre
350rebuilder 02-22-2007 05:36 PM
its already been overbored and i want to put the stroker kit in it....i was just curious as to the difference
JAKE 68 GMC 02-22-2007 06:15 PM
How much is it overbored now? If it's bored .030 over now, and you bore it another .030, that would be .060 over. Combine that with a 383 stroker kit and I believe it would be a 388 stroker.
350rebuilder 02-22-2007 06:48 PM
its just bored 30 over and thats as big as im making it
bondo 02-23-2007 08:49 AM
Then it'll be at 383cid......
curtis73 02-23-2007 10:31 AM
Has it been run at 30-over? If so, its not just as easy as putting new pistons, rings, rods, and crank in it. You can't really run new stuff in used bores. My machine shop won't even assemble a stock shortblock without overboring to the next step. Every piston manufacturer is slightly different. A good machine shop won't even hone a block until they have the pistons in hand to measure.
Poor ring seal, cracked rings, piston slap, and broken piston skirts can result in worst cases. I know you hear about magazine articles that just bottle brush the bores and put new pistons in, but they are only concerned with three dyno pulls. If you're serious about this engine, do it right.
