350 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 05:22 PM
350 question
what size engine CID and liter would my 350 be with the 383 stroker kit and .030 overbore
Old 02-22-2007, 05:25 PM
poncho62's Avatar
Wiki Edits: 5
Doesn't a 383 kit require a .030 overbore?
If so....383/6.3 litre
Old 02-22-2007, 05:36 PM
its already been overbored and i want to put the stroker kit in it....i was just curious as to the difference
Old 02-22-2007, 06:15 PM
How much is it overbored now? If it's bored .030 over now, and you bore it another .030, that would be .060 over. Combine that with a 383 stroker kit and I believe it would be a 388 stroker.
Old 02-22-2007, 06:48 PM
its just bored 30 over and thats as big as im making it
Old 02-23-2007, 08:49 AM
bondo's Avatar
Then it'll be at 383cid......
Old 02-23-2007, 10:31 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Has it been run at 30-over? If so, its not just as easy as putting new pistons, rings, rods, and crank in it. You can't really run new stuff in used bores. My machine shop won't even assemble a stock shortblock without overboring to the next step. Every piston manufacturer is slightly different. A good machine shop won't even hone a block until they have the pistons in hand to measure.
Poor ring seal, cracked rings, piston slap, and broken piston skirts can result in worst cases. I know you hear about magazine articles that just bottle brush the bores and put new pistons in, but they are only concerned with three dyno pulls. If you're serious about this engine, do it right.
305 heads on 350 question buzz1961 Engine 26 07-17-2006 09:43 AM
87 Chevy 350 TBI rod & main Clearance question Mustangsaly Engine 3 05-20-2006 04:18 PM
Question about RamJet 350 iceman36 Engine 1 03-07-2006 10:13 AM
350 rebuilt to 383 question jtswilson Engine 17 03-02-2006 10:54 AM
350 motor question bubb rubb Engine 4 03-25-2003 04:45 PM
