350 rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2002, 03:32 AM
New Member
Post 350 rebuild
Ihave a 4 bolt 350[1984] that i want to put in 77 vette.builing from bare block replacing everything with new parts.just want strong running engine for street use when done.
need help in what size cam ,heads and such for rebuild. thanks
Old 09-05-2002, 04:55 AM
Post
See if you can get specs on the original engine and build it to the original specifications. Unless you just want to build from scratch.
I'm building a 350 4 bolt to put in an '82 pick-up. It's bored .030, balanced, vortec heads, edlebrock performer rpm intake, edlebrock 600 cfm carb with electric choke, hedman headers, 214/224 dur. 443/465 lift @ .050 cam, flat top pistons, heads are port matched to exhaust and intake (not ported or polished), hopefully will be in the range of 340 HP. This will be a daily driver and use pump gas. The cam is similar to a '66 - '67 vette. A cam any bigger will reduce or eliminate most vacuum so if you want vacuum for brakes auto trans A/C and so on I wouldn't go bigger.
Maybe thats enough for you to chew on for a while. Good luck
