350 rebuild not as firm as before - Why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2009, 08:16 PM
Just finished a repair on my 350 tranny, and now it drives "softer". Specifically, I had to replace the forward clutch drum and input shaft, so I had things apart down to the planetary.
Before, this truck would chirp the tires in each gear (it has a shift kit). Now it shifts up and down fine, just isn't as responsive. I'm wondering why.
Here are some possible factors. Could any of these be the cause...
1. I replaced the converter. It's just standard, but my old one was a high-stall.
2. The new forward clutch drum is a little "deeper" than the old one. Hence, there is a larger gap between the pressure plate and snap ring than there was before.
3. I did not flush the cooler or lines. When I originally pulled the pan, fluid looked great and there were no shavings, so I didn't see a need.
4. I disassembled the pump just long enough to inspect it. I'm pretty sure I got everything back correctly.
I'm OK driving the truck as is, I'm just curious why it would perform differently when very little was changed. What am I mising here?
Thanks guys, Chad
Old 09-28-2009, 09:29 PM
SSedan64's Avatar
A converter with stock stall speed should shift firmer than one with a higher stall. Possibly too much clearance between clutch plates, Valvebody gasket may be damaged where the bolt wasn't tightened.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
first 350 rebuild campracing Engine 8 09-10-2009 02:30 PM
350 Engine rebuild CamMan Engine 35 06-01-2006 03:32 PM
350 rebuild techgruv Engine 5 11-26-2003 08:46 AM
turbo 350 rebuild??? 87 gn Transmission - Rearend 4 03-10-2003 01:32 PM
