-   -   350 Rocket Block (http://www.hotrodders.com/forum/350-rocket-block-38769.html)
CLJeepster 05-03-2004 06:44 AM
350 Rocket Block
I have found a Rocket Block 350 and was woundering if any one out there knows what these engines came in stock. And any other information on the Rocket Block 350 would be nice. Thanks.
johnsongrass1 05-03-2004 07:44 AM
Are you referring to the Oldsmobile Rocket or a aftermarket GM Rocket Block?
The GM standard is weak with it's shallow bolt holes and small main studs that pull out. The raised cam "Rocket Block" is built by dart is is a very good piece with as tall as 9.520 deck.
Don't know about the Olds stuff.
