350 Rocket Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2004, 06:44 AM
350 Rocket Block
I have found a Rocket Block 350 and was woundering if any one out there knows what these engines came in stock. And any other information on the Rocket Block 350 would be nice. Thanks.
Old 05-03-2004, 07:44 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Are you referring to the Oldsmobile Rocket or a aftermarket GM Rocket Block?
The GM standard is weak with it's shallow bolt holes and small main studs that pull out. The raised cam "Rocket Block" is built by dart is is a very good piece with as tall as 9.520 deck.
Don't know about the Olds stuff.
