350 roller block - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2008, 07:23 PM
jgh64pkup's Avatar
Last journal entry: new et streets
350 roller block
does any one have a 350 roller block they want to sell?
would it make a good motor?
Old 12-27-2008, 08:12 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yes to both... but my block is in PA
Old 12-27-2008, 08:15 PM
Dammit, I just had one scrapped. I would have given it to you for nothing, with a complete rotating assembly out of my vette. Why do these things always come up a day late?
Old 12-27-2008, 09:10 PM
techinspector1's Avatar
Wiki Edits: 326
That's why I never throw anything away.
pkup, check craigslist. I've found the blocks on there for $75-$100. Sometimes they will still have the lifters, dogbones and spider with them.
Old 12-28-2008, 08:48 AM
Here is some info on a 350 Roller Block Build . http://www.activeboard.com/forum.spa...picID=21028076
Old 12-28-2008, 10:29 AM
jgh64pkup's Avatar
re: 350 roller block
i was going to build a 283 and bore it to a 302 but as they always say bigger is always better so i might as well build a 355
Old 12-28-2008, 12:40 PM
For the price of the components, a 383 would be the best way. good rpm and lots of torque.
Old 12-28-2008, 03:39 PM
DoubleVision's Avatar
I keep every 350 roller block I come across. Especially the 880 castings.
Are they any good you ask? Welp, in the 880`s case factory roller cam, all you gotta do is stick in a aftermarket cam and the rest of the stuff works nicely. Factory windage tray is another added benefit. I`ve always looked at engines from the perspective anywhere I can reduce friction I do, once I went roller I never looked back. I got three blocks under the house that are flat tappet blocks, 2 are 4 bolt heavy duty blocks, one`s a standard 2 bolt and I`ll never use any of them so they`ll likely get sold.
Old 12-28-2008, 03:42 PM
jgh64pkup's Avatar
how much do you want for a 4 bolt hd block
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 10:29 PM
roller cam in an non roller block..is it possible? bigshow2 Engine 5 09-18-2005 08:31 PM
Anything special to put roller cam in 400 block? sb72elcamino350 Engine 1 04-10-2004 12:12 AM
350 Block novatech Engine 2 11-25-2003 09:07 PM
350 block pre-purchase checklist idrva55 Engine 4 01-05-2003 11:52 PM
