350 Runs Rich on one side - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2010, 10:38 PM
Cole's Avatar
Now if I could just afford Gas
Last journal entry: Breaking Bad on the Camaro
This is making me crazy. I have a 1968 350 engine that seems llke it's running rich on just one side (drivers side) of the engine. I know this sounds crazy but it seems true.
Here are the symptoms.
After the car warms up gray smoke starts to come out on the drivers side exhaust. It does not do it at highway speeds, at idle only and it smells like fuel, NOT oil.
Here is what I have done:
Replaced the intake with a Edlebrock Performer EPS and the carb with a Thunder Series 650
Replaced Cap and rotor, also all spark plugs and ran them for 1500 miles and inspected them. They all look like new still (Had to pull them for the compression test anyways)
Ran compression test on all 8 cyls and they pump up evenly to exactly 190 each, in fact they are all almost exactly the same! Engine was warm, all plugs were out and carb removed from intake during test.
Engine Details:
1968 Camaro SS with the 350/295 engine SS package
Camel Hump heads (2 humps) Casting # 3917291
MSD 6A ignition with point distrib
Dual exhaust with no cross connection
Now I am going to ask this at the risk of sounding stupid but is there a chance that the heads are causing this problem?
Thoughts anyone?
Old 01-05-2010, 07:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You undoubtedly have a dual plane intake. This will allow a problem on one side of the carb to show up on only one side of the engine.
I would start with checking real good for any vacuum leaks, and only then continue by balancing the idle mix screws using a vacuum gage, or sensitive tach.
Adjust the screws to get the best idle- the screws should be close to the same number of turns out from *lightly* seated. Don't force the screws in too tight, just lightly seat them before turning them back out. Your manual will have the base settings for them.
Check the rods to see that they are the correct size on both sides. You can do this w/o taking the top off the carb.
If that doesn't help, you may need to open up the carb. It could have a loose jet, a wrong size jet on one side, etc. They are easy to service, the gasket kits are cheap should you tear a gasket.
Old 01-05-2010, 05:09 PM
Cole's Avatar
Dropped another $50 to Jon/legal fund for good luck on my car today!
Everytime I do my car luck gets better!
I will look at the carb but the intake and carb are only 2 weeks old and I replaced them thinking that would fix this problem. I did use a vacuum gauge to set the screws. I adjusted them until the gauge stopped advancing and then made sure both were set the same number of turns out.
that is why I am so bummed, $700 worth of intake, carb and gaskets and ended up with the same problem. Before it actually had a Weiand intake and Holly carb and that intake was NOT a dual plane and it did the same thing. I am thinking I might need to put a plug wire spark tester on each wire and see if something weird is going on there but other than the rich smoke during long idles periods the car runs perfectly. The only vaccum lines are to the PCV on the valve cover and the power assist on the brake boster and they are new too. I took it all apart last night to do the compression test so I will put it back together and test again. I also just spent $130 on some very nice new MSD ignition wires that arrive today so now we have replaced the following:
New plugs/MSD Wires
New Edlebrock Intake and gasket
New Edlebrock Carb and gasket
New Cap and Rotor
New Points
New Vacuum lines
Putting the points and wires in tonight. hoping it's something with the wires at this point.
the old intake and carb were pretty fugly so not feeling too bad about replacing them and the car runs MUCH better with them on now.
Old 01-05-2010, 05:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Any chance that a LEAN condition is fooling you? Or a retarded ignition timing?
If either of these or a combo of both is occurring, the exhaust can reek of fuel- even though it's lean or retarded. This is worse w/a big cam.
If incomplete combustion happens, regardless of the cause, the exhaust will smell "rich".
What do the plugs look like? What is the initial timing, and has the timing tab/mark been verified?
Old 01-06-2010, 08:48 AM
The points probably wont make any difference with the MSD but i think i would switch to an HEI distributor anyways.
Does the engine act like its misfiring or anything? Maybe one cylinder isn't firing and the unburned fuel mixture is pushed into the exhaust and halfway ignited. Otherwise raw fuel must be entering somewhere?
The edelbrock carbs I've had seemed to have problems right out of the box with the float being too high. Also the choke was set wrong, it would never hardly warm up enough to kick the choke off.
If you have a worn engine mount or other problem causing the engine to even slightly lean to one side, any raw fuel entering the intake could run to one side and cause a problem. You mentioned that it only happens when idling for long periods. That sounds like a loading up problem, from a float too high? That problem could easily exist with both carbs. Personally i'd sell them both and put a q-jet back on.
Old 01-06-2010, 06:08 PM
T-bucket23's Avatar
Wiki Edits: 26
How did the plugs look. Were they all the same.
Were the heads planed or the block decked.
What is the vacuum reading at idle
Chet
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 02:51 PM
89 GMC 350 Running Rich bushman Introduce Yourself 2 06-16-2009 10:16 AM
TH 350 lost 3rd gear and reverse is weak junior stocker Transmission - Rearend 1 05-29-2009 05:20 PM
new block mikey1476 Engine 8 04-12-2009 10:34 PM
hot side, 350 tpi engine runs hot on one bank? Ellisb Engine 16 10-27-2002 07:28 AM
