350 sb 1980 blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2008, 09:04 PM
350 sb 1980 blazer
i have recently rebuilt my 350, and installed a rv cam, what would be the best headers to use to complement this cam
Old 09-21-2008, 09:19 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
You might want to check out Hedman "Tork-Step" model which emphasizes lower-midrange torque/lower rpm which is what your cam choice would work best with. Generally, you'll want to stay with anything thats smaller diameter (1-1/2" or 1-5/8") and longer length primary tube (28-33"), and smaller collector diameter (2-1/2") to emphasize that lower rpm powerband. Also consider 2-1/4" or 2-1/2" duals system with an x-pipe or crossover/balance pipe located slighlty rearward of the collectors to further reinforce the bottom end-midrange, as with that RV grind cam you're not gonna need alot of breathing above 4500 anyway. -Just my 2 cents worth, but I'm sure you'll hear pretty much the same from others on this site. Good luck with your setup and keep everyone informed with how your choice(s) works out for you- as that's how we all learn and grow in our knowledge on this site.-Jim
Old 09-21-2008, 09:21 PM
OOOOOPS- I forgot to say- WELCOME to the site.-Jim
Question about Oil presure on a 350 sb??? Robbie Hotrodding Basics 10 09-27-2012 03:04 PM
SB chevy 350 using oil 68 Pickup Engine 5 02-07-2008 06:12 PM
Budget SB 350 TANGO Engine 10 11-12-2007 08:34 AM
91 tbi 350 blazer 210 degrees slyshar2 Engine 2 05-27-2006 12:48 AM
Cam guestion for SB chevy 350 sabino56 Engine 4 08-07-2005 04:13 PM
