350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2006, 09:10 PM
stoney 81ta's Avatar
350 sbc
what would be the stock hp ratings on a 72-73 350.
Old 10-13-2006, 10:13 PM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
350 Power ratings
To answer your question, rather low. In '72, flat cams and large chamber heads knowcked down compression significantly. Also with HP rating being taken at the rear wheels instead of the flywheel, the numbers were rather unimpressive. You could expect a brand new 350 in a Camaro in those years to only develop around 230hp or less.
Speedshift
Old 10-16-2006, 08:57 PM
A stock 350 as installed in a '72 Nova with factory dual exhaust was rated at 200hp net at the flywheel, with all accessories installed. The same engine in '71 was rated 270hp gross, with open exhaust and no accessories. This is basically the same engine as the current standard Goodwrench crate motor, with large-chambered heads and dog-dish pistons.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Would like a stronger sbc 350 than stock heads. StingRay69 Engine 6 11-12-2005 03:22 PM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
