350 SBC, 2 bolt main. Planning to go to 383. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 08:15 PM
gmac@uugghh?.me's Avatar
Would be apprentice.
Is it worth the time and money to build a two bolt main 383 SBC?
Old 02-02-2012, 08:28 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
yes it be fine.. add arp studs...
Old 02-02-2012, 08:47 PM
if you already have the 2 bolt main then it should be fine..i had a 2bolt stroker for years that was pushed hard.
Old 02-03-2012, 04:31 AM
Last journal entry: update
2-bolt blocks usually don't develop cracks in the main webs, this is a common problem with factory 4-bolt blocks. 2-bolt is fine for sustained 450 HP 350 at a sustained 6000 RPM, plus occasional 200-HP hits of nitrous, on a progressive controller. I know because I've done it, without ARP studs. I use the old Jacobs' Mastermind, and had the on set for 50% at 3000, 100% at 6000. Never hurt anything. Ran that for 3+ years, daily street plus dragstrip trips.
Old 02-03-2012, 07:24 AM
Rught on guys, thanks for clearing that up, id been getting mixed answers from the guys iv asked. Ill build 'er up. HAZAAA
Chevy 350 2 bolt main or 4 bolt main? daledouglas Engine 5 07-21-2011 05:10 PM
planning the 10 bolt build up elcaminodragster Transmission - Rearend 4 11-28-2008 01:04 PM
2 bolt vs 4 bolt main 350 small block CanadianCory Engine 9 10-30-2005 09:31 PM
2-bolt main vs. 4-bolt main chevy hause Engine 5 10-26-2005 01:37 PM
What main cap girdle would you recommend for a chev 400 with a 2 bolt main stonedchihuahua Engine 19 01-05-2003 05:31 AM
