350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 04:22 PM
350 sbc
on a carter carb , i took the air and fuel jets out to clean them and forgot how many turns it was to set it close...so i turned them 2 times out on both of them and done a burn out but it died soon as i letted off of it...also what could i look at when one week i'll run a 9.80-10.03 then the following week i run 10.23-11.45 in a 1\8 mile track..i replaced everything when i built the motor but the valves..put a .485 lift cam and springs and hydrolic lifters...
Old 04-22-2012, 05:16 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If your talking about the air fuel mix just turn them in until it starts to die out then back them out slowly till it clears up. and on you time difference how is the car hooking up are you spinning ?
Cole
Old 04-22-2012, 06:37 PM
sbc
no im not spinning anymore..im runnin on street tires not slicks,on a slimmited slip rear end.. never had this problem last year
Old 04-23-2012, 09:04 AM
What were the weather conditions when you raced? This tine of year the weather changes so much and so quikly it causes bad days and good days at the track. Its best to keep a log and record dates, and weather conditions every time you race.
Old 04-24-2012, 06:01 AM
sbc
now im having problems out of the carb.turned it 1 half turns like recommended and when im doin a burn out it sounds like its popping but clearly i can see gas popping up threw the carb when its popping doin a burn out plus it dies as soon as i let off the gas... what else could be wrong with this thing
SBC 350 / SBC 383: Verification Tips and Methods lt1silverhawk Hotrodding Basics 8 06-17-2011 12:21 PM
350 sbc with t-350 Trans, size of bolts to blockneeded? Canuckcamaro Transmission - Rearend 2 03-10-2011 06:46 PM
newer sbc 350 to older turbo 350 yragat Transmission - Rearend 8 10-20-2007 07:52 PM
SBC 350 and Turbo 350 OR 2 spd Powerglide??? boneyard Buick Engine 5 04-04-2006 12:34 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
