350 sbc
1 Attachment(s)
Hi guys i have a 79 corvette l82 that has a steel crank and pink rods in it . I want to liven it up but first want to know should i stick with the crank and rods .
I'm doing a 30+ bore so i need a good set of pistons edelbrock rpm heads edelbrock performer intake and will be running a street avenger 670 i currently have a comp cams magnum 270 cam wanna wake it up but not go made, gas in the uk is *** ripping may be to 350 hp open to idea's thank martin |
pink rods will handle all the power performer heads can ever supply. the GM steel crank is good for over 500 hp. Do standard tests on crank for straightness and round. 400 hp is considered mild now a days
how does this sound to you?and this is a little out of character for me as my vette(similar to your vette) is a gas guzzler now.
111145-10 CL111145-10 272 278 219 225 .510 .525 110 106 Hyd. Hyd. 1,2 1500-5600 Fair idle, Performance Street, Nice streetable mid range power this or similar hydraulic roller,especially with the lower intake centre line. 750 cfm edelbrock performer air gap,less than 10:1 CR,not sure what petrol you have there? 1 5/8 tube headers into 3 inch mandrel exhaust ( do you have the cross member that allows true dual exhaust? heads rpms are ok heads.if you have a th 350,change that out for a 4 speed auto,,2 reasons,lower 1st gear ratio will make that car jump and O/D will save fuel,especially if you get a lock up converter.16 -1800 stall.this combo will exceed 350 hp and be very drive able.If you have the fibre glass rear leaf,change that too,also check trailing arms for separation,mine did under accelleration,, what rear gear ratio were you blessed with? |
You have licked the top end limitations. The crank and rods are way overbuilt for the original engine’s installed power, so what you need is a decent set of pistons. For this you want some good flat tops or D dish types if you need to lower the compression in line with what the octane of the fuel is that you wish to use. For a performance street engine hyper-eutectic castings are fine. But in keeping with the theme of this engine before it was choked up with SMOG reduction changes; a forged piston would be appropriate. For the street, I prefer alloy 4032 which is closer to the silicon contend of hyper eutectic pistons. This makes the forging more temperature stable so it can be run with tighter side clearances that are more like current production engines. This keeps the pistons quiet, reduces the chance of busting the skirt, and minimizes blow-by by keeping the ring package square to the cylinder wall which increases fuel efficiency and power while reducing emissions. The 2618 alloy will take more abuse as it absorbs some punishment but it expands and contracts a lot with temperature and that demands loose clearances which rattle the piston till it gets warmed up. I would make an eductated guess that with your part choices, on an engine dyno this would show about 420 hp around 6000 RPM, while a sturdy output is by no means a race engine so I'd go with the 4032 alloy piston as they're plenty strong enough and won’t bring cold running problems of noise, fragging the skirts, and high blow by. Bogie |
thanks guys any pistons in mind i just loked at the je pistons and they aint cheap are they thanks martin
good parts cost a little more. I have wiseco in my engine.Ive used TRW,,,
| All times are GMT -6. The time now is 05:44 AM. |
