Thread Tools Search this Thread share on Facebook
  #1
Old 01-09-2012, 11:40 PM
Jouba Jouba is offline
350 sbc to bore, how much?
Can i use a oversize block bore of 60 thou to build a high horse power motor (600). i have a motor that needs to be bored to 60 thou. it will be mainly used for the street and sometimes at the strip for a test. i would also like to stroke the 350 to a 434 if possible. The block is 350 h block. any help please.
Register now (free) or login to remove ads
Old 01-09-2012, 11:52 PM
whyholdback whyholdback is offline
Last journal entry: update
Better to find another block. Start with the '87-up, they tend to clean up at 20 over. Plus they have provisions for roller lifters.
A 350 at 20 over, with a maximum stroke of 4", makes 406, not 434. A 434 is a 400 bored 30 and given a 4" stroke.
Old 01-10-2012, 12:36 AM
thanks, can i not stroke the motor with a stroker kit for beter displacement.
Old 01-10-2012, 06:17 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is online now
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
If you had an aftermarket block most definitely. I have never clearanced a stock block for a 4" stroke but I imagine you may run into an issue with how much material you take out.. Cam to crank clearance will also be an issue with a stock block. My machinist just switched his 434ci to a raised cam block because his cam was barely clearing and the base circle was already reduced on it.
Adding a 3.750" stroke in a 350 is pretty common and requires minimal block clearance. Ive clearanced a couple of blocks for these and usually the area just below the pan rails get into the way. I have seen a couple where the bottom of the cylinder can get into the way also. This summer I'm building a 4 bolt 350 roller with a 3.875" stroke. That should be fun to clearance!
Old 01-10-2012, 01:43 PM
Putting a stroker kit in a 350 will get you anywhere from 383 to 408 cubic inches. Not that many kits are good for 408 cubes and 600 HP.
Why invest in cubic inches, anyway? A Chinese turbo or 2 from e-bay will get any mild 350 to 600 HP much cheaper than a correctly-built 434. As long as you keep it from ever having any detonation, stock parts can survive, though nearly everyone would do forged pistons to be safe.
Old 01-11-2012, 05:05 AM
turbo 35o
Yes you right but I am still a old stock guy. i have seen what you guys have in USA, we have attended the SEMA Show last year. (Awesome) and here in South Africa to find a manifold to support a turbo on a 350 is not even a option - none available. i still battle to get by 383 stroker with all the right groceries to run a 12 second quarter mile. best time was a 13.05. maybe the turbo is another option, i have good contacts after the show to import the manifold. thanks for your comments!!
Old 01-11-2012, 05:14 AM
Fast EFI
I purchased a FAST EFI at the Nationals in October last year, when we came back to South Africa i immediately installed the EFI on my 383 Stroker and removed the Holly 750 DP. my problem now is that my car is now a full second slower on the quarter mile. With carb previous best is 13.05 and with the EFI first run 13.72 and then a 14.00. any suggestions or is this proof that a carb is still the best?? i can feel the car struggle half way down the Q/mile.
Old 01-11-2012, 07:58 AM
No, it doesn't prove a carb is better. It proves you don't yet have the EFI dialed in.
Old 01-12-2012, 11:22 PM
efi
Thanks that is what i hoped to hear. i still need to sort out the mixtures.
Old 01-13-2012, 09:56 AM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
Are there no big block Chevy motors over there? 600 hp with a 454 would be somewhat easier to achieve and should last longer.
Old 01-13-2012, 10:41 AM
killerformula's Avatar
killerformula killerformula is offline
Last wiki edit: Carburetor
Last journal entry: Its ALIVE!!!!
Wiki Edits: 3
600 horse on a factory 350 block, pre or post '87 is a grenade. Especially if you're boring it to the limit. The only way I'd attempt that is less bore, and a fill in the block. By the time you do that and worry about all the other associated issues you may as well go aftermarket or big block.
K
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 sbc to bore, how much?"
ThreadThread StarterForumRepliesLast Post
Spread Bore VS Square Bore AdvisedavehEngine2201-05-2012 06:35 PM
Edelbrock square bore to spread boreGUITAR1989Engine1508-01-2011 06:04 AM
spread bore to square bore adaptor?david ahluwaliaEngine1103-21-2009 06:15 AM
anyone ever able to fit 3.76 bore pistons in a 3.5 bore engine?74chevyflatEngine1505-21-2006 07:58 PM
Spread bore with square bore carbwestern starEngine510-28-2004 01:16 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
