Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 SBC Build Help
Old 06-09-2005, 12:01 PM
Mustangsaly's Avatar
Mustangsaly Mustangsaly is offline
think 10.25:1 CR is to much ? or will it be that high cause, if 454C10 is right The head gasket adds 8cc and the piston in the hole adds about 4cc = 12cc + 76cc = 88cc heads. or is the 10.25:1 piston have the extra 12cc figured in ?
thanks
Northern Auto Parts said,
Yes, we can substitute pistons on these kits to roughly achieve a
compression ratio of 10.25:1. In order to accomplish this, you would
need a piston with a .275 dome (H617CP). The upgrade on the street
performance kit would be $106.40 for a total of $566.39.
However, there is one note of caution in using this configuration. Compression ratios in excess of 9.5:1 are NOT recommended for use on pump fuel unless you are running aluminum heads. The extra 5 horsepower you may achieve may not worth be the trade off of $5 per gallon race fuel. If you have any more questions, feel free to call us at
800-831-0884.
-----Original Message-----
Mustangsaly Asked:
i was looking at this kit, Chevy 350 (to 1985) STREET PERFORMANCE -
HP350KHW Hypereutectic Pistons with Scat Crank.
http://www.northernautoparts.com/Pro...oductModelId=1
1497 Hypereutectic pistons... can substitutions be made on pistons ?
pistons i need are .30 over, and i'm wanting around 10.1.1 to 10.5.1 CR
Hypereutectic Pistons with 76cc heads, a i haven't picked a cam yet, .......
http://www.northernautoparts.com/Pro...tModelId=11497
