i have a fresh set of 76cc heads that come off a 383 that had 3000 mi on them, is a 10.25:1 CR SBC Motor with 76cc Heads with stainless 202 160 valves a good choice ?
Heads cost $250 think thats a deal ?
(if im right it will end up less than the 10.25:1 CR when you figure the piston in the hole & head gasket)
does anyone have any sbc heads that are runable or don't need a much, or won't cost a bunch at the machine shop they want to sell ???
Heres a Link You Pick what you think is right 4 my build,
what cam , lifters , timing chain , gaskets , oil , pump , would you pick 4 my setup ?
motors not apart yet, so woud wait & see or just put new rods & crank in ? there not big bucks. scroll down to pick ...........
http://www.northernautoparts.com/Pr...ductModelId=380
what do you think of my cam choice ?
Comp 1800-5800 RPM # 12-211-2 270/270 adv duration .470/.470 lift Valve Springs must be changed,Not Computer Compatible + $76.55
Are the 76cc Heads the Best Choice for a 10.1 CR motor ?
engine asembly isn't a issue,
Thanks
Mustangsaly
