350 sbc distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 12:00 PM
350 sbc distributor
in the process of getting all my parts to build my engine(80-85 sbc 350). looking for 350 hp. i dont have a distributor. i am on a budget. should i get a used one? if so what years? or should i buy a cheap on of ebay? whats everyones thought. sorry if this has been brought up before i searched and couldn't find much.
Old 01-20-2011, 12:18 PM
BOBCRMAN@aol.com's Avatar
If you buy used HEI get one built in the seventies. Vac advance unit. Before computer controlled spark. Check for shaft/gear wear. Replace internals.. New aftermkt stuff can be had cheaper.
Old 01-20-2011, 12:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It would depend on how much money you had to spend for a distributor. To decide which way to go after-market or stock. JMO
Colw
Old 01-20-2011, 02:13 PM
1983 Z28
Do a quick search, I bought a unit from Skip White on Ebay and made a thread about it. It's actually very nice, and after a comparison, it's actually the exact same unit as MSD's Street Fire distributor and the Jegs/Summit brand distributors.
Old 01-20-2011, 02:38 PM
Mertz's Avatar
I found a new MSD Ready to Run on ebay for about half price. It works great. I see that MSD is making a module to fit in the old points type that works similar to the Pertronix. You just attached it to the points plate and go. Easier than the Pertronix and the distributor would be very cheap. I run a Pertronix on my Corvair and Catalina and they work great.
Old 01-20-2011, 02:42 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
^^^ I would second Jr. the 6500-R from skip is a good bet for about 50 bucks, also get a crane 99619-1 limiter plate to limit the vacuum advance, another 5 bucks but skip does not sell them, try summit.
Make sure you check for firewall clearance the skip HEI is a full size unit and some cars won't accommodate that size.
TJ
Old 01-20-2011, 03:07 PM
eloc431962's Avatar
Wiki Edits: 37
TJ
Sounds like a good enough price.
Cole
Old 01-20-2011, 08:07 PM
FastOrange's Avatar
it is NOT the same as a StreetFire, ive had both, they are very similar, but different.
Old 01-20-2011, 09:01 PM
thanks guys. i will try out the skip white.
distributor chevyman420 Engine 2 10-13-2008 07:30 PM
HEI Distributor on a 289 V8 Ronald J Berry Sr Engine 3 08-25-2008 05:56 PM
Distributor help..... rocket87 Engine 3 08-24-2008 04:50 PM
hei distributor aceofspades49c Engine 8 05-01-2006 02:06 PM
distributor 72CutSupreme Engine 1 03-01-2005 10:10 PM
