Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 sbc fouled spark plugs
Old 07-16-2012, 01:36 PM
oldbogie oldbogie is online now
Originally Posted by grandslam1991 View Post
Yes the intake installed about 2000 miles ago, and i believe i bought fel pro gaskets and had my mechanic the intake. Maybe ill replaced those gaskets and see if it helps.
While I do suspect the intake gaskets, I start with pulling the rocker cover and check the valve motion first as this is easier than getting the intake off and allows ruling the cam lobes in or out as a problem with a minimum of effort before pulling the intake.
Bogie
