I am in the process of building my engine for my NOVA. I started with a 350 four bolt main. It is bore .030 over. I had the crank polished. INstalled stock replacement pistons. I am installing a .244/.244 solid lifter cam. I am putting 327 double hump heads with 1.94 intake valves. I have a 700 cfm edlebrock and a edlebrock torker intake (the original). Also long tube headers. I have a HEI dizzy. I will be putting a 2800 stall converter thru a th350 built for street and strip. Any guess on my hp/tq to the wheels?
This is the cam I am thinking about putting in it. Cam and Lifters, Mechanical Flat Tappet, Advertised Duration 282/290, Lift .520/.540, Chevy, Small Block, Kit
That's going to be a high RPM motor, hope you have valve springs and that your pistons keep up with the demand! I'm not 100% sure about your compression but I'll call it 9.5:1. Given that I'd say you'd make 375 horse up front and be putting down 290 or so out back-
Not really sure what you are talking about. Why wouldnt the pistons keep up. If that isnt a good cam choice what would be good for street/strip applications?
Brand Isky Racing Cams
Manufacturer's Part Number 201292
Part Type Camshafts
Product Line Isky Hydraulic Flat Tappet Camshafts
Summit Racing Part Number ISK-201292
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,800-7,000
Intake Duration at 050 inch Lift 244
Exhaust Duration at 050 inch Lift 244
Duration at 050 inch Lift 244 int./244 exh.
Advertised Intake Duration 292
Advertised Exhaust Duration 292
Advertised Duration 292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.505 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.505 in.
Valve Lift with Factory Rocker Arm Ratio 0.505 int./0.505 exh. lift
Lobe Separation (degrees) 108
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible No
Grind Number 292 Mega
Quantity Sold individually
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
