350 sbc idle problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2012, 05:04 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
I just put a 350 in my 65 impala. I am having an issue when the car is ideling. The car starts up and runs beautiful. No back fires, no knocking, no over heating. After running at idle for 5 to 10 minutes, the car dies. The engine will start right back up and run after this point, but will die again at idle. I have a 4 barrel edelbrock carb on it. I have replaced the fuel filter, fuel pump, spark plugs and wires. The timing is correct as well. I thought maybe a vacuum leak but I'm not sure
Old 09-10-2012, 06:23 PM
blwn31's Avatar
Vapor lock?
Keith
Old 09-10-2012, 06:53 PM
Ive never had an issue with vapor lock before. What exactly causes it and how is it fixed?
Old 09-10-2012, 07:25 PM
Would a bad ignition module be a possibility?
Old 09-10-2012, 09:32 PM
spinn's Avatar
Possible , but how about the choke. If it runs beautiful the compression , an d timing are right. No reason to suspect internal problems. Sounds like the idle needs to be set for hot and cold operation.
Today was like 71 degrees, vapor lock is not suspect to me.
Old 09-10-2012, 09:54 PM
How do I know if its the choke?
Old 09-10-2012, 10:15 PM
spinn's Avatar
The spring heats up and releases, or kicks down to hot idle with a snap. If the spring is broke, or linkage binding it may not release. This will hold the throttle tab off the screw. A 65, Qjet what type a choke does it look like? is this the original qjet?
SBC 350 idle issues jwnova Engine 93 03-23-2012 06:19 PM
350 sbc wont idle 72ardosnova Engine 3 12-15-2011 10:34 PM
350 tbi idle/ put in drive stall problem HELP ghomer Engine 8 08-19-2009 08:56 PM
sbc carb/idle problem 67stpside Engine 1 12-12-2006 10:52 AM
sbc 350 miss under idle Walker Engine 2 07-29-2003 09:02 PM
