So did it run before? Sounds like you are a tooth off, retarded timing. Bring to TDC on your timing mark, make sure you are compression stroke. Set dist. in pointing to #1 ON THE CAP. Does this help any?
Before you pull dist out, you will see you are a tooth off. Pull dist and then you will have to geta long screwdriver and turn the oil pump shaft until dist. drops right in where you want it.
