-   -   350 sbc pistons (http://www.hotrodders.com/forum/350-sbc-pistons-164760.html)
Thumpr 09-08-2009 03:47 PM
350 sbc pistons
Anyone know the difference in a 80s 350 sbc piston and a LS 350 sbc piston. I was told the can be exchanged. I have a new set of LS pistons and want to put them in my 80s 350. Figured I might even have to go with a stroker crank. Anyone done this swap ?
GMC boogie 09-08-2009 04:45 PM
I don't see how they would work, different bore & stroke combinations betwwen the two.
whynot 09-08-2009 05:29 PM
Well honestly I am not sure about the stroke. But on the box it says the bore is 4.0300, Which I think a 350 is 4.000 Maybe boring will take care of that. Might have to take it to a machine shop to get the pin height.
Thumpr 09-08-2009 05:41 PM
Yes thats what it says. Taking it to a machine shop is no problem. If they will be able to tell me the difference in the pin heights. Just figure someone in here would know.
GMC boogie 09-08-2009 06:01 PM
Gen 3 Stock LS1 bore is 3.908. Gen 1 Stock 350 bore is 4.00.
It's gonna rattle a bit.
techinspector1 09-08-2009 06:02 PM
I think you'd have about as much luck as trying to make a Ford piston work in the Gen I.
Gen I 350
1.560" compression height
0.927" wrist pin diameter
Gen III, IV
1.338" compression height
0.945" wrist pin diameter
I don't think the valve reliefs will line up either.
I've done this kind of hokey stuff in the past and have ended up spending more money than if I had used the correct parts in the first place. Sell those pistons to someone who needs them and start fresh is my best advice to you.
